Hello Guest it is October 21, 2026, 10:51:57 AM
Author Topic: oscillating tangential knife  (Read 25689 times)
Re: oscillating tangential knife
« Reply #10 on: January 22, 2010, 03:36:09 PM »
I to need to make a tangential knife for my router maybe you could help me out as to where to start. Like some pictures so i can see what you have done?
 First question does it connect directly to your spindle and does the spindle handle the indexing?
 Second question is your knife a wheel like a pizza cutter?
Thankx in advance
Mike Scott
Offline Bill_O
  •  615 615
« Reply #11 on: January 25, 2010, 08:28:03 AM »
The knife does not attach to the spindle. The spindles I use are just a high frequency motor with no encoder for indexing. The knife I have is a heavy duty exacto blade or a utility knife blade. The part that holds the blade can be removed and a wheel can be used instead.
