Hello Guest it is November 13, 2026, 05:13:36 PM
Author Topic: HOLD machine via LPT pin?  (Read 40466 times)
Re: HOLD machine via LPT pin?
« Reply #20 on: October 23, 2009, 11:36:51 AM »
I forget to try, will ask. I hope, in HOLD position, pins state changed by modal codes don't reverse, isn't it? Not fatal, but better is to stay in place...
« Reply #21 on: October 23, 2009, 12:03:53 PM »
Sorry I dont what you are either saying or asking.
« Reply #22 on: October 23, 2009, 12:17:29 PM »
Mxx somewhere in the program changes output state of pin X from LOW to HIGH. I'm holding the Mach3 via LPT. What will happens with the pin X output level? Will go back to LOW or will stay HIGH as I ordered with Mxx?
Modal code for "coolant" for example, but this is just for example...
« Reply #23 on: October 25, 2009, 05:12:31 PM »
Hi Hood,
I checked... No surprise for you: of course NO acceleration and decelaration when opening the window.   :(
Frankly speaking: After Art said this, I didn't even believe that there woud be proper start or stop...
Konrad
« Reply #24 on: October 25, 2009, 05:19:15 PM »
Konrad, thanks for testing it out, would have been a handy thing if it did work.
resume the gcode
« Reply #25 on: December 02, 2009, 09:06:04 AM »
Hi all!
Can you tell me about the resume of  last situation of g-code ,after user close the mach3 ?
By the way when we need to work off ,how can we  save the current gcode so user resume it(the next line of gcode) at last day!?
thanks.
mostafa
