Hello Guest it is November 13, 2026, 06:41:22 PM
Author Topic: general questions  (Read 10263 times)
general questions
« on: October 22, 2009, 09:44:10 AM »
For an active high home switch setting you would need a normally closed switch correct?  I am using the switches from probotix right now until I can get my boxes done for the optical photo-interrupters.
While in the table display mode in mach3 the display view point is from the Zaxis looking down and out towards the y axis motor or handle correct?
please be kind as I am trying to relearn a lot of stuff.
Offline Fastest1
  •  920 920
  • Houston, TX
Re: general questions
« Reply #1 on: October 22, 2009, 09:55:48 AM »
Look in the "members docs" I believe the rule of the right hand will explain it. I personally thought it was laying on the table  looking up into Z?
