Hello Guest it is October 22, 2026, 11:47:22 PM
Author Topic: New Plugin Interface for Rev4  (Read 9660 times)
« on: October 21, 2009, 10:19:55 AM »
Hello,
I have done a first draft of the new plugin interface for the Mach3 Rev4. This interface changes some of the var names (Less then 5%) and a few other minor changes. This Doc I hope will show the amount of work that is needed to convert a plugin from Rev 3 to Rev 4 . This should allow for any version of C++ to be used when I am finished but I need to make some new methods for getting and setting Strirngs. The reason for this is that CStrings are not part of the C++ STL :(  More on that later as I finish it up.
Please tell me if you have a hard time following the guide.
Brian
BTW this is only for the plugin authors
www.newfangledsolutions.com
www.machsupport.com
Re: New Plugin Interface for Rev4
« Reply #1 on: October 21, 2009, 04:33:54 PM »
Thank you Brian, for the "How To" and what the changes are!!!
Scott
