Hello Guest it is November 23, 2026, 03:27:26 AM
Author Topic: Our Spindle BrushlessMotor and Controller in mini-machine  (Read 9340 times)
« on: October 20, 2009, 08:49:04 PM »
we are a manufacturer of brushless DC motor and control ,now we have a series of Brushless DC Motor Drive Unit is designed as specific systems for some small milling machine and Drilling Machine,This control system with perfect function, simple operation, capability of anti-interference, energy saving, low breakdown rate and easy maintenance which can achieve maximum torque and smoothness when at low speed.
motor power:
1100W 3500RPM OR 6000RPM DC300V
1500W 3500RPM OR 6000RPM DC300V
2200W 3500RPM OR 6000RPM DC300V
controller:Input AC110V or AC220V
The new features of B brushless motor controller use in mini-machine
New Function
1:Torque 0 ~ 5V Analog Output
For example: the corresponding 0 ~ 3N.m
2:0 ~ 10v Analog Input
For example:Minimum Speed ~ maximum speed(400rpm~6000rpm)
3,Drivers can access AC110V/220V two kinds of voltage, in the same drive can be switched
web:www.sangmutan.com
E-mail:
info@sangmutan.com
« Last Edit: October 20, 2009, 08:52:09 PM by sangmutan »
