Hello Guest it is September 24, 2026, 02:03:10 AM
Author Topic: Cut a circle?  (Read 32827 times)
Cut a circle?
« on: October 20, 2009, 07:41:45 PM »
Maybe just me, but I have never been able to get the NF wizards to cut a circle.  I have never really gotten any use out of the NF wizards because I just don't trust them,  if I can't get it to cut a circle. Andy's circle routines work fine.  Please help.  I'm using 2.83
I entered:
Tool Dia .1875
X center 0
y center 0
Circle dia 1.0000
Cut outside
Depth .008
Rapid height .5000
Step depth .008
G code I get:
(Code by Newfangled Wizard, 10/20/2009)
(Version 2.83)
(Program Posted for Aluminum )
G0 G49 G40.1 G17
G80 G50 G90 G98
G20 (Inch)
(***** Circular Groove/Cutout *****)
M6 T1
M03 S4000
M7 (Mist On)
G00G43 H1 Z0.5
G00 X0.7812 Y-0.1406
G42 P0.09375
G01 X0.6406 F9.9
G02 X0.5 Y0 R0.1406
G01 Z-0.008 F4.95
G03 X-0.5 Y0 R0.5
X0.5 Y0 R0.5
G00 Z0.5
G02 X0.6406 Y0.1406 R0.1406
G40
G00 X0.7812 Y0.1406
M5 M9
M30
Offline TDAY
  •  165 165
    • Home CNC Stuff
Re: Cut a circle?
« Reply #1 on: October 22, 2009, 11:56:48 AM »
What is it doing or not doing? Tried it here at it worked for me.
Troy
"I try to put forth the effort,before asking a dum question"
http://homecncstuff.elementfx.com
Re: Cut a circle?
« Reply #2 on: October 22, 2009, 08:01:38 PM »
Did you try the code as I posted it, or try the wizard.  If the wizard works for some people and not for me I want to find out why.  It makes a circular shape of some sort, just not a circle.
Offline TDAY
  •  165 165
    • Home CNC Stuff
Re: Cut a circle?
« Reply #3 on: October 23, 2009, 06:26:46 AM »
 I am using version 2.83 of wizards and used the wizard with your inputs,and looks good here.
Seems i had a "ODD" shaped circle one time,and this is what fixed it.
Goto....Config> General Config>, and check to see you have Constant Velocity selected,Distance Mode is Absolute, and IJ mode is Inc.
Also when you run a Cut Circle make sure the CV Mode LED is on.
HTH
Troy
Re: Cut a circle?
« Reply #4 on: October 23, 2009, 06:29:26 PM »
The cut circle routine uses a circular lead in and lead out so you will see several moves besides the circle you want. The ramp in and out are properly handled if you ask for a groove the lead happens above the work- clearly it doesnt help with the cut, but it still makes a lead in.
In addition to the circular lead in there is a linear move to turn on the cutter comp.
As far as I know the circle routine works for all cases, Ive tested it a lot and i use it fairly often.
