Hello Guest it is October 21, 2026, 09:01:25 AM
Author Topic: G76 Threading Wizard ?  (Read 25622 times)
« on: October 15, 2009, 10:23:15 AM »
Is there a wizard to produce G76 code ?
Or could someone post code for 1.5mm pitch thread 8mm dia x 20mm long in full G76 format
So i can configure my Post Processor
Phil
Re: G76 Threading Wizard ?
« Reply #1 on: October 15, 2009, 12:52:32 PM »
The simple threading wizard does G76. A look in the Turn manual will give you all the words that can be used, which are needed and which are optional.
« Reply #2 on: October 15, 2009, 03:22:08 PM »
Sorry thought G32 was the simple one.
When i run my cam generated code i get the chamfer at the beginning of the pass rather than at the end, but it is all in the order is documented in the manual.
I just wanted to see where the error was, i will go and produce some code now.
Thanks Hood
« Reply #3 on: October 15, 2009, 03:25:38 PM »
Order shouldnt matter.
« Reply #4 on: October 15, 2009, 03:41:08 PM »
OK, if it doesn't matter about order i may have another problem.  ;D
I'm only dry cutting at the moment.
The X & Z both feed in together then there is a small X movement, then the Z moves at pitch speed.
When that Z depth is reached there is a G00 out on the X axis then a G00 feed on the Z axis back to the start when it all repeats.
I have already found other error in the Post Processor for Screwcutting.
Phil
« Reply #5 on: October 15, 2009, 03:51:56 PM »
What CAM are you using?
« Reply #6 on: October 15, 2009, 04:53:05 PM »
FWIW,
How about using the wizard and generate the same code. Only difference change the M0176.mis file such that it will generate code for  G76 and then for a G32.
« Reply #7 on: October 16, 2009, 03:17:45 AM »
Hood, Thanks OneCNC
One error i have noticed with the post processor is if i fill in the box for a 3mm retract the post processor adds a decimal point so i get a .3mm pullout.  ???
Rich, Thanks i have just tried the wizard "Simple Threading" that produced G76 code.
I am now going to try the Mach code.
Phil
« Reply #8 on: October 16, 2009, 03:58:03 AM »
OK just tried the Mach code and have some questions.
On ports/Pins, Turn options there are some default values for threading.
Do these values over ride what is posted in the code if a value is included in the code or only if a value is missing from the posted code
These would be listed as optional on page 10-16 on ver 1.84 manual. ?
Phil
« Reply #9 on: October 16, 2009, 04:07:59 AM »
They should only be used if none are in the code. The wizard also has additional settings which you get to by pressing the Settings button in the wizard.
