Hello Guest it is September 26, 2026, 01:43:39 AM
Author Topic: Parallel Port 2 Pin Status  (Read 9271 times)
« on: October 11, 2009, 11:05:56 PM »
Are there OEM LED codes for monitoring the pin status of a second parallel port? Where might I find the codes? I would like to add a parallel port 2 pin status to a diagnostics screen like the one that exists presently for port1
Sam
Offline Mattw
  •  41 41
Re: Parallel Port 2 Pin Status
« Reply #1 on: December 29, 2009, 09:23:34 PM »
I too would like to know this, but here is what I did to get around it.
When you assign a particular pin to an output or input in Ports and Pins, you can use the macropump to evaluate the IsOutputActive() or IsActive() and then SetUserLED() accordingly.
Here is a sample from my macropump...
'Spare output 7
If IsOutputActive(Output7) Then
   SetUserLED(1000,1)
Else
   SetUserLED(1000,0)
End If
