Hello
Guest
it is
October 25, 2026, 10:11:08 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Parallel port problem
« previous
next »
Print
Pages:
1
2
3
Go Down
Author
Topic: Parallel port problem (Read 39075 times)
bobbya47
93
Re: Parallel port problem
Reply #10 on:
October 11, 2009, 08:32:34 AM »
No printers
bobbya47
93
Reply #11 on:
October 11, 2009, 08:46:30 AM »
Her is my test setup
Carnoustie, Scotland
Reply #12 on:
October 11, 2009, 08:59:55 AM »
I would suggest you unplug all and test direct on the port, if that checks out then move down a piece at a time.
bobbya47
93
Reply #13 on:
October 11, 2009, 04:01:32 PM »
I have a second computer with the same motherboard (Asus P5PE-VM) and the same processor. I ran the pp monitor and it is identical. Pins 1-16 hi. The driver test is excellent but still no control.
Reply #14 on:
October 11, 2009, 04:03:49 PM »
Have you tested direct to the port instead of through the cable?
bobbya47
93
Reply #15 on:
October 11, 2009, 04:18:01 PM »
Yes, pins 1-16 hi just like the port monitor says.
Reply #16 on:
October 11, 2009, 04:24:32 PM »
Then I dont have an answer and I find it very strange that two computers onboard ports and a PCI card are all defective in exactly the same manner. Hopefully someone will think of a reason.
bobbya47
93
Reply #17 on:
October 11, 2009, 04:29:29 PM »
I have not ran mach on the second computer but both port monitors look identical. I believe the ports are ok. I think something is keeping the mach driver from working. By the way, thanks for the help.
Reply #18 on:
October 11, 2009, 04:34:15 PM »
Do the DROs move in Mach when you jog?
Do you see a pulse frequency and a Time in Int on the Diagnostics page?
If all of the above is correct and you have definitely got the correct port address in then I am at a loss to what the problem could be.
bobbya47
93
Reply #19 on:
October 11, 2009, 04:43:20 PM »
Yes, all that is working.
Print
Pages:
1
2
3
Go Up
« previous
next »
