Hello Guest it is November 22, 2026, 07:03:45 AM
Author Topic: Won't Home With Joystick Active  (Read 8921 times)
« on: October 10, 2009, 10:13:45 AM »
I've used Key Grabber to get my Logitech Freedom 2.4 wireless joystick to work just as I wanted but when I went to home the machine it moved each axis a small amount and zeroed the DRO's long before it hit the home switches. I haven't changed any configuration settings but I checked them to make sure. Everything seems to be right. I can restart mach3 without Key Grabber and it homes as it should. Run Mach through Key Grabber....Nada. Any ideas what could be happening?
Ryan
