Hello Guest it is November 11, 2026, 10:17:14 PM
Author Topic: XSVF error PLEASE HELP  (Read 12165 times)
« on: October 02, 2009, 08:08:16 AM »
I bought a G100 driver for use with Mach 3.
I have this manual for install the Gecko G100 (G100_Set_Up_Guide_Rev.1_9-19-07).
I can do all steps of instalation before Page 19 of 32 of the manual, but when I press run button I have this error:
<6>May 26 20:20:16 [1]: Download manager started
<6>May 26 20:20:19 [2]: ifconfig: ipaddr=C0A801C8/FFFFFF00 dhcp=no
<6>May 26 20:20:19 [3]: Starting network...
<6>May 26 20:20:20 [4]: IF_ETH0 is down
<6>May 26 20:20:23 [5]: CRC_OK -- yes
<6>May 26 20:20:23 [6]: Auto boot DLP in 10 sec
<6>May 26 20:20:33 [7]: Attempting to run DLP (auto_boot timeout)
<6>May 26 20:20:33 [8]: Loading FPGA config 1...
<3>May 26 20:20:33 [9]: XSVF error!  Error code 2 = TDO mismatch
<6>May 26 20:20:33 [10]: Programming time = 38ms
<6>May 26 20:20:33 [11]: Config completed
<6>May 26 20:20:43 [12]: Ethernet interface is up at 192.168.1.200
<6>May 26 20:24:17 [13]: Ethernet interface is up at 192.168.1.200
<6>May 26 20:24:42 [14]: Deleted file # 1, free space now 1048576
<6>May 26 20:24:59 [15]: Deleted file # 1, free space now 1048576
<6>May 26 20:25:02 [16]: Wrote 55632 bytes to 1
<6>May 26 20:26:19 [17]: CRC_OK -- yes
<6>May 26 20:26:19 [18]: Updated firmware OK
<6>May 26 20:28:10 [19]: Deleted file # 1, free space now 1048576
<6>May 26 20:28:13 [20]: Wrote 55632 bytes to 1
<6>May 26 20:28:41 [21]: CRC_OK -- yes
<6>May 26 20:28:41 [22]: Updated firmware OK
<6>May 26 20:28:47 [23]: CRC_OK -- yes
<6>May 26 20:28:47 [24]: Loading FPGA config 1...
<3>May 26 20:28:47 [25]: XSVF error!  Error code 2 = TDO mismatch
<6>May 26 20:28:47 [26]: Programming time = 37ms
<6>May 26 20:28:47 [27]: Config completed
I think that is a problem with .XSVF file, I download the file from http://www.machsupport.com/plugins.php [Motion Plugin - v3.037  (March 5, 2008)]
I try a lot of times with this, in the UPLOAD FPGA configuration I prees test and this is the result:
<6>May 26 20:29:08 [28]: Loading FPGA config 1...
<3>May 26 20:29:08 [29]: XSVF error!  Error code 2 = TDO mismatch
<6>May 26 20:29:08 [30]: Programming time = 37ms
<6>May 26 20:29:08 [31]: Config completed
I can connect with the G-rexloader withou problems, I can ping the driver and else steps before.
What can I do?
I have the license of Mach and the license of Mach for this plugin.
Please help us.
Gastón Bua Bonaldi.
Lineartec S.R.L.-
