Hello Guest it is October 20, 2026, 03:04:38 PM
Author Topic: Macro Error, Buffer Over Run  (Read 29098 times)
Re: Macro Error, Buffer Over Run
« Reply #10 on: September 24, 2009, 06:30:45 PM »
Hood,
What does the Maro Error, Buffer over Run mean?
« Reply #11 on: September 24, 2009, 06:38:23 PM »
Not exactly sure, sounds to me like a macro is being run and its looping.
« Reply #12 on: September 25, 2009, 03:45:40 AM »
Hood,
Based on your observations and my reviewing my setup, I have made some changes.
Input Signals:
Probe remains as you found it.  That is for my Zero Touch Plate.
E Stop - I am using Pin 10 instead of Pin 14.
THC ON - I have disabled this input.
OutPut Signals:
No change OutPut #2 and #4 are active.
Spindle Relay Control:
M3 Remains as Output #2 Active
M4 is a Mach default value Output #1 is inactive.
Flood Mist:
M7 Remains as Output #4 Active, I turn my laser on for my X,Y location macro.
M8 is a Mach default value Output #3 is inactive.
I have tested these changes and things are still working.
Thanks for the suggestions.
« Reply #13 on: September 25, 2009, 05:13:11 AM »
You meaning you are still having the problem or meaning its working fine now?
« Reply #14 on: September 25, 2009, 08:00:53 AM »
When I run the GCode at 6 IPM, I still get the Macro Error.  I would like to understand why that error is happening.  There must be a problem if I am getting an error.  I am not run any macros when I get this error.  I don't ge the error if I run at a faster speed.
I have modified my Ports and Pins based on the information you gave me, Thanks
I have a cut problem and I slowed the machine down so I could trouble shoot some things.  I am getting a regular pattern in my cuts.  I tried a different computer but the cut quality did not improve.  I cut the GCode on the other computer on a different but like machine and there is no problem on that machine.  It has been suggested that the regular pattern is more likely do to signal problems and not mechanical problems.  But I have also checked the mechanical issues and I believe the machine is tight.
Any suggestions would be helpful.
« Reply #15 on: September 25, 2009, 08:12:08 AM »
How much backlash do you have? looks very much like backlash issues.
« Reply #16 on: September 25, 2009, 08:15:16 AM »
Will run your code and xml tonight and see if I can find an issue, so can you post your latest xml and also if you could zip the macro folder and attach that
