Hello Guest it is October 20, 2026, 03:59:03 PM
Author Topic: Help me find parallel port card and cables, please.  (Read 13131 times)
Offline Mattw
  •  41 41
« on: September 19, 2009, 08:59:52 PM »
So, I'm looking for 25-pin straight through cables.  I have questions in to a few ebay sellers, but nobody seems to specify if all the pins go through.
Also, can someone point me to a parallel port card that is known to work with mach / breakout bords. (i.e. I've read that some have lower voltages and cause problems.)
Offline Mattw
  •  41 41
Re: Help me find parallel port card and cables, please.
« Reply #1 on: September 19, 2009, 09:09:46 PM »
Ok, scratch the cable part... I found some on ebay right after posting.
I still need guidance on a parallel port card though.  Thanks.
« Reply #2 on: September 19, 2009, 09:28:15 PM »
Make sure the card is Windows XP compliant. Buy locally with the understanding that if it dosen't work you will get a full
 refund.
« Reply #3 on: September 20, 2009, 01:37:53 AM »
Do a search on this forum. I posted the card and the exact drivers you need to work with MACH, and how to set it up.
Offline Mattw
  •  41 41
« Reply #4 on: September 20, 2009, 10:25:35 AM »
Thanks Simpson!  I just ordered 'er up.
