Hello Guest it is November 11, 2026, 01:46:50 PM
Author Topic: Solid simulation - Integrate Mach3 with Vericut or Camplete True Path..?  (Read 9840 times)
Offline cnc-it
  •  153 153
Wouldn't it be great if a program like vericut or camplete Truepath could be integrated into Mach to give solid simulation when running a program. Would save having to design a solid sim program from the ground up..
http://www.camplete.com/truepath/collision.html
These programmes are for verifying G code but also allow for complete ground up machine design so you could create an identical model of your own machine in the sim and it would run the sim as the G code was executed in real time!!
The Mazak Matrix control has this and it looks awsome!! They even put the pallet and tool changer in the sim!
John.
« Last Edit: September 17, 2009, 07:24:39 PM by cnc-it »
