Hello Guest it is November 22, 2026, 08:23:24 AM
Author Topic: Gcode/post processor help G77  (Read 26305 times)
Re: Gcode/post processor help G77
« Reply #10 on: September 17, 2009, 05:10:57 PM »
Its not in the folder of my current xml folder name ,if that makes sense, should it be ?
Phil
« Reply #11 on: September 17, 2009, 05:49:43 PM »
If you have installed mach to the default location it will be in C:\Mach3\Macros\Mach3Turn
If you have a custom profile then there is a chance you didn't clone it from a turn profile and if thats the case then you will not have these macros there, just copy them over from the Turn folder.
