Hello Guest it is October 25, 2026, 02:18:17 PM
Author Topic: Different Cuts  (Read 24225 times)
Offline kolias
  •  1,165 1,165
Re: Different Cuts
« Reply #10 on: September 14, 2009, 11:44:45 PM »
On the ‘Program Run” screen press the ‘M-Codes’ button at the bottom of the page and you will see that M30 is ‘Program end and rewind’. Thus your last line is beyond the end of your file and won’t ever be executed. Move it up a line so it is run before the end of the file (M30) and you should be OK.
HTH
al
Thank you Al
Nicolas
