Hello Guest it is November 01, 2026, 10:13:33 AM
Author Topic: Sample Sign  (Read 18351 times)
Offline kolias
  •  1,165 1,165
Sample Sign
« on: September 13, 2009, 11:37:36 AM »
I made this sample sign in Acad which looks good in Acad.
Then I export it to a dxf file and then import it to LC and I see this large black rectangle and in the lower left corner I have my sign which I can hardly see it.
Where the large rectangle comes from? (pls see attached files)
The sign was made at 0,0 in Acad and then I moved it around but the results are the same
Nicolas
Nicolas
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Sample Sign
« Reply #1 on: September 13, 2009, 12:12:04 PM »
Hi, Nicolas
You have a line in your drawing and you need to Explode the Text in your Cad program.
Hears a dxf to look at.
Chip
Offline kolias
  •  1,165 1,165
Re: Sample Sign
« Reply #2 on: September 13, 2009, 12:25:17 PM »
Hi, Nicolas
Chip
Thank you Chip, your dxf looks fabulous
And how do I Explode the Text?
Have lots to learn I guess but getting there little by little
Nicolas
Nicolas
Offline Chip
  •  2,055 2,055
Re: Sample Sign
« Reply #3 on: September 13, 2009, 12:35:36 PM »
Hi, Nicolas
It's a feature in most Cad programs, What Cad are you using ?
You select the Text and it turns it into lines and arc's.
Chip
Offline kolias
  •  1,165 1,165
Re: Sample Sign
« Reply #4 on: September 13, 2009, 12:44:38 PM »
Hi, Nicolas
Chip
I use Version14 but thanks I got it but I have a different problem now.
Look in the attached LC file, the text is not lined up at all on the sign plus the letters have no consistent spacing
Any ideas what is causing that?
Nicolas
Nicolas
Offline Chip
  •  2,055 2,055
Re: Sample Sign
« Reply #5 on: September 13, 2009, 12:54:04 PM »
Hi, Nicolas
I get the same thing if I don't explode the text hear.
Ver14 of what Cad program ? Autocad, Turbocad, ......... ?
Chip
Offline kolias
  •  1,165 1,165
Re: Sample Sign
« Reply #6 on: September 13, 2009, 12:58:02 PM »
I use Acad V14
Nicolas
Nicolas
Re: Sample Sign
« Reply #7 on: September 13, 2009, 01:44:53 PM »
You can't explode the text in AutoCAD 14, unless you have a copy of the Express tools, which was an extra cost add-on back when V14 was out.
The EXPLODE command won't do anything with text.
Re: Sample Sign
« Reply #8 on: September 13, 2009, 01:46:38 PM »
You might want to try doing your text in a program like this, then bring the .dxf into AutoCAD.
http://www.dwgtool.com/outline.htm
Offline kolias
  •  1,165 1,165
Re: Sample Sign
« Reply #9 on: September 13, 2009, 01:51:41 PM »
You are right Gerry, I do have the Explode Command in my Modify Menu but it does nothing, when I select the text it says is not the right type.
I will give a try to the program you mentioned
Nicolas
Nicolas
