Hello Guest it is November 23, 2026, 09:05:23 PM
Author Topic: Lacycam export to mach issues  (Read 10126 times)
Offline vadude
  •  18 18
  • WYSIWUG
« on: September 12, 2009, 02:56:56 PM »
I have a licensed mach3 with an unlicensed lazycam.I am able to upload a dxf file with a rectangle drawn in it to Lazycam.I inserted a text " test" into the rectangle & then deleted the rectangular outline.
I see the file as fomatted corectly in Lazycam/.However after loading it successfully into mach3,all i see is a series of vertical & horizontal lines without the text that i am after.
   When I tried to cutting it,i see the machine trying to cut a pocket to the size of the rectangle without the rquired test.What am i doing wrong here?
No Pain No Gain
Re: Lacycam export to mach issues
« Reply #1 on: September 12, 2009, 09:34:18 PM »
I replied to your same / other posting of the same topic.
RICh
