Hello Guest it is September 23, 2026, 05:51:31 AM
Author Topic: Tool change location button  (Read 15565 times)
H2ODIVER
« on: September 01, 2006, 12:41:00 PM »
This is probably very simple but I seem to be overlooking the answer. How do I change the coordinates (X,Y,Z) for the "Tool Change Location".
Is this changed within Mach 3 as a setting or are these coordinates set when I load my G-code from my pp.
Thanks in advance for everyones help.
Chris
Re: Tool change location button
« Reply #1 on: September 01, 2006, 02:26:10 PM »
Should find it on the settings page.
H2ODIVER
« Reply #2 on: September 01, 2006, 08:43:00 PM »
Thanks for the reply Hood,
I guess I was a little too general in my last post. I see where one can change the coordinates on the setting page... trouble is for some reason it will not allow me to change the coordinates. I can type in numbers but when I click out of the box my new coordinates do not save.
How do I get these new numbers to save?
Thanks for any help.
Chris
Offline Garyv
  •  103 103
« Reply #3 on: September 01, 2006, 09:25:23 PM »
I think I had the same problem when I set mine up just hit the enter key to enter the changes on each one ..
    I hope that helps ..
H2ODIVER
« Reply #4 on: September 01, 2006, 09:31:36 PM »
Ok, Now I feel really dumb   :-[
Sometimes the simplest things escape my grasp.
Thanks Garyv for your help.
Offline Garyv
  •  103 103
« Reply #5 on: September 01, 2006, 10:16:24 PM »
Not a problem ,,, hey I did the same thing until i got a little agravated with it and just hit the enter key and it put it in ..
      Good Luck getting it running
« Reply #6 on: September 02, 2006, 07:43:23 AM »
Just an FYI  you will need a new tool change macro to read the tool change pos from the DRO's. If you would like I can post a new tool change macro (there are many that have asked about this in the past few weeks)  and upload it to the FTP server.
Brian
www.newfangledsolutions.com
www.machsupport.com
