Hello Guest it is November 23, 2026, 02:34:17 PM
Author Topic: Feedrate override chage increase/decrease%  (Read 20722 times)
Offline asrin
  •  19 19
« on: September 01, 2009, 05:06:51 PM »
First of all, sorry for my English language, so I am from the Netherlands.
I have a problem with the Feed Override function in Mach3 Mill.
When I in-/decrease the value, it changes with 10% off the feedrate.
Is it possible to change this in 1%. For the spindlespeed you can change this in the general config, but I can't find this for the Feedrate.
I hope you can help me.
With kindly regards from the Netherlands.
Re: Feedrate override chage increase/decrease%
« Reply #1 on: September 01, 2009, 05:24:26 PM »
You could probably do it via VB in a button or even a brain.
Best option would be an analogue input and use a Pot to adjust , this would give infinite adjustment within the range. You would need hardware to get your analogue input though :( I use the Pokeys  for that and it works well.
Offline asrin
  •  19 19
« Reply #2 on: September 02, 2009, 02:34:51 AM »
Hi Hood,
Thanks for your reply. I give it a try.
Kindly regards from the Netherlands
« Reply #3 on: September 02, 2009, 02:42:57 AM »
I just put this in a VB button as a test and it works fine
FRO = GetOemDRO(821)
UNIT= 2
Call SetOemDRO(821,FRO-UNIT)
« Reply #4 on: September 02, 2009, 02:55:05 AM »
You could also set up a user DRO on screen so that you could set the unit without having to edit the VB Button
What you would do is put a user DRO on screen, that would allow you to type what you want the % reduction/increase to be. In the below example I made a UserDRO and had an oem code of  1111 for it, the VB in the button would be
UNIT= GetUserDRO(1111)
Offline asrin
  •  19 19
« Reply #5 on: September 02, 2009, 03:08:24 AM »
Hi Hood,
That's  a quick answer.
I have tryed the code and it "WORKS". That's  the most simple way.
Very nice, I am happy with it.
Have a nice day
Riny
« Reply #6 on: September 02, 2009, 04:09:09 AM »
