Hello Guest it is November 22, 2026, 10:43:16 AM
Author Topic: Step & Dir Pulse  (Read 44320 times)
Offline kolias
  •  1,165 1,165
Step & Dir Pulse
« on: August 26, 2009, 03:59:35 PM »
On the motor tuning screen we have the entries for “Step Pulse” and “Dir Pulse”
Is it important to set the right values there?
Should I ignore these entries?
Nicolas
Nicolas
Re: Step & Dir Pulse
« Reply #1 on: August 26, 2009, 04:06:47 PM »
The values are in u seconds. Some drives specify a preferred value.
Does your drive mention anything on the duration?
Offline kolias
  •  1,165 1,165
« Reply #2 on: August 26, 2009, 04:36:33 PM »
The drives manual only says: “Minimum pulse width for the step pulse is 5 uS”
ok so I know the minimum but what is the maximum? Is there an average value? Is it by trial and error?
Questions, questions,….heck if I don’t ask I will never learn
Nicolas
Nicolas
« Reply #3 on: August 26, 2009, 04:43:23 PM »
Set it to 5 and it should be fine :)
« Reply #4 on: August 26, 2009, 04:47:44 PM »
Hood,
What is the max duration that MACH will use if input, know off the top of your head?
Offline kolias
  •  1,165 1,165
« Reply #5 on: August 26, 2009, 04:50:56 PM »
Which one? Step Pulse, Dir Pulse or for Both?
Nicolas
Nicolas
« Reply #6 on: August 26, 2009, 04:59:27 PM »
both
Offline Britt
  •  10 10
« Reply #7 on: August 27, 2009, 12:19:34 AM »
Er... if it says 5 ***min*** pulse, shouldn't it be set something above 5? Like 7 or 10?
« Reply #8 on: August 27, 2009, 02:26:39 AM »
You can please yourself what you put but remember more isnt always better ;)
If a manufacturer only gives you one figure then that is what I personally would use, it would be a bit stupid of them to quote a figure that is borderline  so I would think 5 would be perfect. :)
Offline kolias
  •  1,165 1,165
« Reply #9 on: August 27, 2009, 07:58:15 AM »
5 it is for both Hood, thank you
Nicolas
Nicolas
