Hello Guest it is October 23, 2026, 05:15:57 PM
Author Topic: No Shuttle?  (Read 15735 times)
Offline kolias
  •  1,165 1,165
No Shuttle?
« on: August 24, 2009, 02:47:46 PM »
Every time I start my machine there is the following message in the status line:
“No Shuttle detected of type selected”
I have set my motors and steps and they work well and I don’t touch these settings any more. So why I always get this message? Should I worry about it or just ignore it?
Nicolas
Nicolas
Re: No Shuttle?
« Reply #1 on: August 24, 2009, 03:02:01 PM »
Actually just go into your mach 3 directory and then into the plugins folder and delete the shuttlePro.dll  plugin and then it will not show that message anymore  ;)
Re: No Shuttle?
« Reply #2 on: August 24, 2009, 03:03:53 PM »
Its because the shuttle plugin is loaded by default for some reason, think it may have been sorted now but not sure. Anyway its an easy fix, go to the plugins folder and either delete the shuttle plugin or change its file extension to m3p. Changing to m3p is probably the best way as if in the future you do get a shuttle then a double click on the shuttle.m3p will again install it.
Offline kolias
  •  1,165 1,165
Re: No Shuttle?
« Reply #3 on: August 24, 2009, 05:18:44 PM »
Out of curiosity what the shuttlepro.dll  is used for?
Nicolas
Nicolas
Re: No Shuttle?
« Reply #4 on: August 24, 2009, 05:21:11 PM »
ShuttlePro pendant thingy ;D
Re: No Shuttle?
« Reply #5 on: August 24, 2009, 05:22:09 PM »
« Last Edit: August 24, 2009, 05:24:16 PM by budman68 »
Offline kolias
  •  1,165 1,165
Re: No Shuttle?
« Reply #6 on: August 24, 2009, 06:25:27 PM »
Well now that is a Gadget, pretty cool
Nicolas
Nicolas
