Hello Guest it is November 11, 2026, 11:22:29 PM
Author Topic: Homing my lathe, please help  (Read 29551 times)
Re: Homing my lathe, please help
« Reply #10 on: September 10, 2009, 07:24:12 PM »
rich,
  your math worked out perfectly for me but sadly the x axis and z axis still moves when i try to home the machine.
« Reply #11 on: September 10, 2009, 09:31:35 PM »
You followed my reply #7 exactly?
 What version of Mach are you using?
Can you post XML file for the lathe your using.
« Reply #12 on: September 16, 2009, 07:00:38 PM »
sorry for the delay, i have the newest version of mach 3 its like version x.x? im not really sure but i just purchased the license for the program also. Im not too clear on what you mean by the xml of my lathe but i do have their website on it if that helps you at all. Also if the machine is not homed out will that cause the z axis to constantly stop about .100 thousands short on every pass of a turn cycle? It almost looks as if i was making a taper on the part. Here is that link http://www.mini-lathe.com/Mini_lathe/Reviews/Homier_7x12/Homier_7x12_p1.htm
« Reply #13 on: September 16, 2009, 08:41:04 PM »
DId you do exactly what i posted in reply #7?
« Reply #14 on: September 16, 2009, 08:56:06 PM »
I did it exactly, but it still wants to move, its doesnt like rapid or move quickly but small steps.
« Reply #15 on: September 16, 2009, 09:17:48 PM »
Post your XML file.
It will be located in the directory where Mach was installed:
C:\MACH3
the file name is: Mach3Turn and the file extension in windows will be "XML Document". Make a copy and give it
name like MIKEYZ and post it and i will take a look at it.
« Reply #16 on: September 16, 2009, 09:35:17 PM »
i will grab that tomorrow for ya rich and hopefully it will show the problem i am having with this. Thank you for hanging in there with me on this one
« Reply #17 on: September 17, 2009, 02:55:09 PM »
See if this will help you rich
« Reply #18 on: September 17, 2009, 05:20:32 PM »
sent you a personal message.
