Hello Guest it is October 20, 2026, 03:05:05 PM
Author Topic: ACAD gCode  (Read 14297 times)
Offline kolias
  •  1,165 1,165
ACAD gCode
« on: August 21, 2009, 04:58:54 PM »
I made a simple drawing in ACAD and managed to make it a .tap file for mach3. I attach the file here hopefully you can see the gcode.
My concern is the movement of Z axis, I don’t want a large movement because it will crash the home made pen I made.
N20 G0 Z1.0000
N35 Z0.1000
What Z1.0000 and Z0.1000 means? If it raises first the Z axis one of them should be a negative number but I cant see that
Can someone explain please
Nicolas
Nicolas
Re: ACAD gCode
« Reply #1 on: August 21, 2009, 05:08:45 PM »
How did you create the tap file , hand code it of a have it generated by a program?
Re: ACAD gCode
« Reply #2 on: August 21, 2009, 05:18:16 PM »
The top of your work piece should be Z 0.  Z1.000 IS ONE inch above.  Z.100 IS one hundred thousands above.
A negative Z would be below the top of your work piece. Hope this helps.
Ed
Ed VanEss
Offline kolias
  •  1,165 1,165
Re: ACAD gCode
« Reply #3 on: August 21, 2009, 06:24:10 PM »
I used LazyCam, Open DXF, Output (post gCode). My first try and worked, only I cant read gcode properly
Ed answered my question, Thanks
Nicolas
Nicolas
Re: ACAD gCode
« Reply #4 on: August 21, 2009, 07:42:19 PM »
Take a look at Tutorial #6 and section 8.3.4 "Cut Depth" in the manual.  ;)
