Hello Guest it is November 10, 2026, 02:19:00 AM
Author Topic: Machine coordinate by a VB fonction  (Read 13293 times)
« on: August 21, 2009, 10:19:19 AM »
Do we have a way to switch from Machine coordinate to Program Coordinate with a VB fonction?
Re: Machine coordinate by a VB fonction
« Reply #1 on: August 21, 2009, 01:50:15 PM »
Yup,
Code "G53"
« Reply #2 on: August 24, 2009, 10:13:27 AM »
Ok thank's
Here's another question... In a VB script, how can we know if the machine coords button is active? Some kind of protection.
ie: if machine coords is active, stop the routine and show a alarm.
Thank's
vmax549
« Reply #3 on: August 24, 2009, 10:21:10 AM »
(;-)  THere are 3-4 ways to switch to MACHINE coord depending on exactly what you need. There is also an LED that indicates when Mach is in machine coord mode.
They are listed in the cutomizing mach2 manual(;-)
« Reply #4 on: August 24, 2009, 10:26:25 AM »
I don't really want to switch to machine coordinates. I want a warning if I try to run a VB script (ie: z probing) and machine coordinates is active.
Fred
vmax549
« Reply #5 on: August 24, 2009, 03:38:11 PM »
" There is also an LED that indicates when Mach is in machine coord mode."
« Reply #6 on: August 25, 2009, 07:34:07 AM »
Dim Test as Boolean
Code "G80G90G50"
Thank's, here's my solution for my problem. I added this portion of code to all my probing macros...
Test = GetOEMLed(16)
If Test then
    Message "***DONT PROBE IN MACHINE COORDS"
    Exit Sub
Else
End if
« Reply #7 on: August 25, 2009, 07:43:03 AM »
oups sorry...
Dim Test as Boolean
Code "G80G90G50"
If Test then
    Exit Sub
Else
End if
