Hello Guest it is November 22, 2026, 12:41:43 PM
Author Topic: Threading problem  (Read 24500 times)
Threading problem
« on: August 20, 2009, 12:59:28 PM »
Hello, I'm running v3.042.027  I'm running the following code to test a threading operation.  When I load the code I get an error message that says, "non integer value for integerline 14."  This is just a simple 1" 8tpi routine.  Can anyone suggest why mach3 turn doesn't like it?  If it matters, I used turbocad v 14 and their cam plugin to create the code.
% ( MYAPP01 )
O1
G20
G00 G40 G49 G80 G90
( TOOL COMMENT IS NOT FOUND )
T0101 M06
G00 G90 G54 S779 M03
G43 H1 M08
( OPERATION NAME = OPERATION-1 )
F19.5
( NO COMMENT FOR THIS OPERAION. )
G00 X1.483 Z1.
X0.983 Z0.079
M24
G76 X.998 Z-0.7473 K0.05 D0.02 P1
M05
G91 M09
G00 G28 X0. Z0.
M30
Thanks in advance for your help!!!
Re: Threading problem
« Reply #1 on: August 20, 2009, 01:20:12 PM »
Update: I upgraded to v029 and I still have the same problem.
« Reply #2 on: August 20, 2009, 01:46:04 PM »
Bob,
Why not just use one of the threading wizards?
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #3 on: August 20, 2009, 02:08:38 PM »
Hi, Bob
There are 2 things Mach isn't liking in the Plug-in post, see note's in code.
; bob.mullikin
% ( MYAPP01 )
O1
G20
G00 G40 G49 G80 G90
T0101 M06
G43 H1 M08
F19.5
G00 X1.483 Z1.
X0.983 Z0.079
M24
;G76 X.998 Z-0.7473 K0.05 D0.02 P1
G76 X0.998 Z-0.7473 K0.05  P1 ;------------ This isn't a valid word for G76 line-------- "D"0.02
;G76 X-0.998 Z-0.7473 Q1 P1 l45 H0.005 I29 C0.1 B0.036 T0
;G76 X-0.036 Z-2 Q1 P0.05 l45 H0.005 I29 C0.1 B0.036 T0
M05
G91 M09
; G00 G28 X0. Z0. ;-----------mach needs these on sep. line also
G00
G28 X0. Z0.
M30
Chip
« Reply #4 on: August 20, 2009, 02:14:52 PM »
You have  D0.02 in the G76, what is that meant to be? It is not a recognised word for Mach G76 and will be your problem.
Also notice you have a M24, what is that, User macros should really be over 100.
Edit see chip beat me to it ;D
Offline Chip
  •  2,055 2,055
« Reply #5 on: August 20, 2009, 02:23:33 PM »
Hi, Hood
Hood 7,619 Chip 1,983, How many lap's down is that.  :D
Chip
« Reply #6 on: August 20, 2009, 02:29:18 PM »
Thanks for the input.  I figured it was something like that.  I've had other issues on the mill side with the turbocam code.
I looked for the threading wizard, and couldn't find one.  The only one I found was a milling thread wizard.  That would be an easy way to solve my problem.  Anyone have a link?
« Reply #7 on: August 20, 2009, 02:34:19 PM »
Are you using MachTurn? if so the simple threading wizard should be included with it.
« Reply #8 on: August 20, 2009, 02:41:05 PM »
Hood, I thought so too, but I've looked several times and didn't find it.  As a side note, my wife always finds something I'm looking for after I've looked for it and failed.  So I tell her, I'll look again, but I"m pretty sure it's not there.  Once in a great while, I'm right.
« Reply #9 on: August 20, 2009, 02:56:37 PM »
LOL, well extract this into the C:\Mach3\TurnAddons folder.
