Hello
Guest
it is
November 12, 2026, 03:18:03 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Third party software and hardware support forums.
Galil
(Moderators:
smurph
kcrouch
Mitsubishi HF-SE Ac servos and drives.
« previous
next »
Print
Pages:
1
2
3
4
Go Down
Author
Topic: Mitsubishi HF-SE Ac servos and drives. (Read 73059 times)
battwell
129
Re: Mitsubishi HF-SE Ac servos and drives.
Reply #30 on:
June 16, 2011, 03:13:01 AM »
no.
the 3.5kw requires 3 phase 220v (not 380v like we have in uk) to produce the output, single phase to run the drive electronics (split into 2 seperate circuits)
they let out a very loud bang if you connect them to 380v... dont ask!
Logged
if its not broken yet, fit more gadgets!
cnc-it
153
Reply #31 on:
June 16, 2011, 03:28:50 AM »
Yep just checked again, no UK sigle phase! So for the 2KW motor I would have to find a 400v drive to run 3 phase and no way I can run single phase without a converter.
http://cgi.ebay.co.uk/Mitsubishi-MR-J2S-350A-MRJ2S350A-AC-Servo-Drive-/120727350270?pt=LH_DefaultDomain_0&hash=item1c1be92bfe
John
Last Edit: June 16, 2011, 03:31:44 AM by cnc-it
Logged
battwell
129
Reply #32 on:
June 16, 2011, 03:43:59 AM »
il be honest, ive never tried to run just single phase on the larger units. if i get time il wire up a 2kw j2s today and try it see if it errors or outputs.
i know i read it on some of mitsubishi literature somewhere though.
most of my machines use up to 750watt mitsi, which are fine on single phase.
my big machines ive left with original dc motors and run via galil. this is one of them
http://www.youtube.com/watch?v=qqQqNpQkD4c
what are you converting?
Logged
cnc-it
153
Reply #33 on:
June 16, 2011, 04:27:10 AM »
Just looked at the Mits manual for J2S series. It says the single 230v is only available for the 70 drive or smaller..
I'm retroing a Denford Triac with the old steppers on. It's in new condition so though it would make a good single phase project and a good way to get my head round the Mitsubishi drives and motors.
Will check your galil machine out
John
Logged
Print
Pages:
1
2
3
4
Go Up
« previous
next »
