Hello Guest it is October 16, 2026, 01:19:39 AM
Author Topic: which drive  (Read 14438 times)
which drive
« on: August 28, 2006, 06:26:30 AM »
I am converting small mill (Dyna 2800) to run from MACH3. My steppers are 8 wires 200 steps. Can you suggest suitable drivers to buy. Will it be better to get G-rex (as far as I understand 1 board drives up to 6 axes) or  3 separate drivers, one for each motor.
Thank you
Re: which drive
« Reply #1 on: August 28, 2006, 09:24:19 AM »
THe Grex is a step direction generator, you would still need drivers. I dont know if your motors are bipolar, if they are, I would go with Geckos (201) But I gues it all depends on what size (amps and volts) the steppers are.
Regards
Fernando
Re: which drive
« Reply #2 on: August 28, 2006, 11:46:56 AM »
Hi Fernando
Thank you for clarifying.
Re: which drive
« Reply #3 on: August 28, 2006, 11:53:38 AM »
Not a problem.
Just to clarify furthermore, the grex ys a pulse generator capable of generating much more pulses per second than the parallel more. (tens or hundreds of times more, I cant remember which) but it just generates the pulses substituting only the parallel port, you still need the controller (Mach2/3) and the drivers. If you post the characteristics of your motors, perhaps we can suggest which types of drives to use.
If using big-is motors on an production machine, I would suggest geckos, if smallish motors on a hobby once a week use machine, then I might go with xylotex or something similar.
Regards
Fernando
Re: which drive
« Reply #4 on: August 28, 2006, 04:49:58 PM »
2.3Amp steppers from Escap. They are 1.8.
There are 8 wires coming out of each motor.
Re: which drive
« Reply #5 on: August 28, 2006, 05:02:00 PM »
You might get by with a Xylotex drive.
www.xylotex.com
but I am biased, i Love My Geckos!
