Hello Guest it is November 26, 2026, 03:23:48 AM
Author Topic: russian words in mach3 screen buttons  (Read 26423 times)
« on: August 19, 2009, 01:25:33 AM »
hello, i am lefrai a new member, I want to know how I can copy russian words from an excel list and then copy them in the masch3screen buttons from my screen, i tried but puts me only ?????? (interrogations signs),
regards
lefrai
Re: russian words in mach3 screen buttons
« Reply #1 on: August 19, 2009, 03:48:31 AM »
Hi Lefrai
what program are using to change the text?
Klaus
The brain isn't a soap, it doesn't shrink when used.
« Reply #2 on: August 20, 2009, 06:24:30 AM »
I use the mach3 screen designer, but I got a list in russian of all the names of the caps buttons, so I just only change the names, with the mach3screen designer, when I want to copy and paste the word in cyrilics, the mach3screen put me ??????, do not acept this kind of fonts with cyrilics caracters.
lefrai
« Reply #3 on: August 20, 2009, 06:47:36 AM »
Hi lefrai,
do get the question marks in the screendesigner when you paste the cyrilics, or in Mach3?
Klaus
« Reply #4 on: August 20, 2009, 06:58:29 AM »
hi,
the marks apears in the mach3 screen designer, just when I try to paste the word in cyrilics. in the rectangle where you have to write the name of the button.
regards
marcelo
« Reply #5 on: August 20, 2009, 07:25:53 AM »
Hi lefrai,
what screendesigner are you using?
Screen3, Screen4, Jetcam Editor, or MachScreen?
Klaus
« Reply #6 on: August 20, 2009, 07:39:01 AM »
its the mach3screen
« Reply #7 on: August 20, 2009, 07:59:45 AM »
Hi Lefrai,
I'm not sure whether I can help you at all. First I don't know if diffrent character sets like cyrilic are supported by Mach3, second if I could help you, it would only with Machscreen. The following procedure assumes the language setting english.
If you would use MachScreen, create a new screen and add a button. Be sure the button is selected and doubleclick in the line of "text on control" the string "text" (the background color changes to blue) and write your text in cyrilic.
Klaus
« Reply #8 on: August 20, 2009, 08:12:08 AM »
ok, thanks by the way, you are very kind
lefrai
« Reply #9 on: August 21, 2009, 01:04:46 AM »
Hi Lefrai,
I thought a bit deeper about your problem. Forget what I wrote before, it is nonsens. The best is to build a bitmap with your cyrillic text and put it on the button.
Klaus
