Hello Guest it is November 13, 2026, 05:19:19 PM
Author Topic: PoKeys and KeyGrabber  (Read 12998 times)
« on: August 18, 2009, 04:46:35 AM »
I would have thought that the PoKey55 would have played well with KeyGrabber to make analog inputs and joysticks very easy for those of us who are
familiar with KeyGrabber. However, I cannot get the config screens in keygrabber to save. If I go through the config and start Mach from the KeyGrabber screen it works quite well. Also the joystick config screen is very jittery/unstable. It takes patience to get all the boxes filled in without errors. It likes to do an auto-select of some kind and jump the info entered in a right hand column to the leftmost column. It helps if I jump all the pots to ground. I tried doing the config with the PoKey unplugged but the PoJoystick config tab doesn't show up. Maybe someone else has gotten this to work.
Offline borisz
  •  220 220
    • www.poscope.com
Re: PoKeys and KeyGrabber
« Reply #1 on: August 18, 2009, 05:25:51 AM »
Hi!
PoKeys joystick and keyboard emulations are produced strictly under specifications, so if there is a problem it is on the keygrabber side.
For jiterry analog inputs: almost every analog inputs is jiterry when it is floating. Connect it to the voltage between 0 and 3.3V. After that it should be stable.
regards
Boris
