Hello Guest it is October 04, 2026, 09:02:37 PM
Author Topic: SS and spindle motor control  (Read 33640 times)
Re: SS and spindle motor control
« Reply #10 on: December 25, 2009, 02:16:43 PM »
Recently I built an PWM-Analog converter of active filters, with adustable amplification for better calibration.
Now as I use it I had other questions raised:
* Does anyone how the PWM resolution changes with PWM frequency?
(Separately for PP output and for SS output)
** At Ports_Pins config, I can only set Step/DIR pins for spindle. IF I configure PWM, then STEP pin becomes the PWM output. OK. ANd what about the DIR pin?
 - If I set it to 0 (supposing I always rotate my spindle one direction only) then mach yells for an error.
 -- If I set it to a certain pin, then what will it do??? (I can configure separate relays for CW and CCW but I do not see where to  assign pins for them)
 --- What If (and this is my case in fact) want to use one pin for direction (HIGH=CW; LOW=CCW) and another pin for Spindle START/STOP (HIGH=GO; LOW=STOP) and a third pin for the PWM signal for speed control?
« Last Edit: December 25, 2009, 02:27:18 PM by hunserv »
« Reply #11 on: December 25, 2009, 04:00:32 PM »
Hi Hunserv,
For the parallel port, the resolution of the PWM is the Mach3 kernel speed/PWM base frequency
So, if you have a Mach3 kernel frequency of 45KHz and a PWM base frequency of say 10Hz, then the resoulution  of the PWM output is 45,000/10 = 4,500 steps between 0% and 100% of maximum speed. So that is 0.022%
Therefore if you have a maximum spindle speed of 10,000rpm, the speed resolution you can get is 10,000 / 4500= 2.22 rpm
For the smoothstepper, I'm not completely sure but I think that the equivalent value for the kernel speed is 4MHz so the resolution is a lot higher.
Cheers,
Peter.
Homann Designs
http://www.homanndesigns.com
email: peter at homanndesigns.com
« Reply #12 on: December 25, 2009, 04:26:25 PM »
Thanks Peter,
Any hints on the 3-wire spindle setup? (pwm, dir, stop)
