Hello Guest it is October 16, 2026, 02:15:09 AM
Author Topic: Reversed Axis (Stepper Motor)  (Read 11367 times)
« on: August 27, 2006, 04:38:20 PM »
I have a home-built machine with a xylotex 3-axis servo suite. X and Z are fine, but Y is reversed. Any idea how to setup Mach to reverse a stepper. I tried inputting a negative number into the "Set Steps per Unit" function - but it shut down the channel.
All help appreciated.
Ben
Re: Reversed Axis (Stepper Motor)
« Reply #1 on: August 27, 2006, 05:01:30 PM »
Config menu then ports and pins then motor outputs. Change the Dir Low active to the opposite of what you have now on the Y axis.
« Reply #2 on: August 27, 2006, 06:55:58 PM »
 :) Thanks Hood. That Worked fine.
Ben
« Reply #3 on: August 27, 2006, 06:57:19 PM »
no problem
