Hello Guest it is October 20, 2026, 04:03:19 PM
Author Topic: Axis Outputs OK but inputs=no go  (Read 14911 times)
« on: August 16, 2009, 07:35:07 PM »
I have been using my table without e-stop or limits since I built it a few month ago. Now that I have ironed out any kinks I have begun to complete the machine. The axis outputs work great however I cannot get the inputs to work.
My driver board has a DB9 connector for the four input triggers. These inputs are sent via opto isolators to pins 10-13 on the db25 connector. I have verified the operation of the limit switches with a meter. With the PC powered up and with the switches open I read 5 volts on pins 10-13 (with respect to pin 25 ground). With the switches closed I read close to zero on the same pins. Mach 3 however does not seem to recognize that there are inputs connected. I am watching the indicators on the diagnostics page. I have enabled the home/limit inputs via "Ports and Pins". Is there something else that I am missing here?
Your help is greatly appreciated.
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Axis Outputs OK but inputs=no go
« Reply #1 on: August 17, 2009, 12:25:09 AM »
Hi, Generatorlabs
Probably just need to change the Active Low "State" and may need to use the Homes & Limits page to change the Home Direction also.
Chip
« Last Edit: August 17, 2009, 12:31:09 AM by Chip »
« Reply #2 on: August 17, 2009, 06:19:42 PM »
I attempted to set all the inputs for limit and home to "Active Low" with no result. With the parallel cable removed from the driver board I can measure 4.7 volts on pins 10-13. I even tried to jump pin 25 to pins 10-13 with a 470 ohm resistor to bring them low and found no response within the on-screen indicators.
If I use keyboard emulation I can see the indicators toggle so I know the program is working. I am having a dilemma with the response of the real world limit switches. Could I be looking at a funky parallel port or is there something else I am missing here?
Offline Chip
  •  2,055 2,055
« Reply #3 on: August 17, 2009, 08:27:35 PM »
Hi, Generatorlabs
Verify that pin 25 is actually a gnd pin, Not all printer port and cables use all pin's 18-25, I usually jumper pin's 18-25 together at a common point,
The 470 ohm resistor isn't necessary as the input's can be hard grounded.
Try this free printer port program ton test them also. http://www.geekhideout.com/
Chip
« Reply #4 on: August 18, 2009, 07:15:00 PM »
To begin, a million thanks for the link to the Parallel Port Monitor. It works like a charm. In fact, it works so good that it proved what a butthead I am. All along my port was fine. In my ignorance I assumed the Zero in the "Ports and Pins" screen was indicating the first parallel port (sort of like how SATA drives do) and I left the default value in there. I was only changing the pin numbers.
So I bow in humility and thank you  :-\
« Last Edit: August 18, 2009, 10:16:15 PM by generatorlabs »
Offline Chip
  •  2,055 2,055
« Reply #5 on: August 18, 2009, 08:35:27 PM »
Hi, Generatorlabs
Well don't feel bad, Weave all done that and have the T-Shirt to prov it, Just put it in the Closet with the rest of them.
That's what I Do, Chip  :D
« Reply #6 on: August 18, 2009, 10:06:35 PM »
Hey Chip,
After the first dozen the shirts come in diferent colors, man i hated the pink ones!  ;)
« Reply #7 on: August 18, 2009, 10:50:04 PM »
Rich,
Send the pink ones to Hood. They go good with his skirt.  ;D
Ed
Ed VanEss
