Hello Guest it is November 25, 2026, 11:33:27 PM
Author Topic: Jogging with Arrow Keys Problem  (Read 121862 times)
Re: Jogging with Arrow Keys Problem
« Reply #40 on: August 15, 2009, 12:10:44 PM »
I will say that I had bought a drive and BOB from them about a year ago and they were excellent with customer support and even called me to help me with my setup.
Good people from my experience-
vmax549
« Reply #41 on: August 15, 2009, 05:05:31 PM »
DID you try swapping out the cables?? THis could easily be a bad connection or cable??? It is not always the drive(;-)
Just a thought, Before you BUST their chops,    (;-)TP
Offline kolias
  •  1,165 1,165
« Reply #42 on: August 15, 2009, 05:14:07 PM »
Actually I checked the continuity of the pins on each cable and it was ok.
There are 3 ribbon cables connecting the 3 drives to BOB. I did not mark which one goes where but I doubt it that they all went to the same drive as before. Therefore I would say yes I swapped them
Nicolas
Nicolas
« Reply #43 on: August 15, 2009, 05:21:33 PM »
So did you ever check the wiring conections to the motors?
Just sounds like it's exactly what I had going on.
Offline kolias
  •  1,165 1,165
« Reply #44 on: August 15, 2009, 05:25:47 PM »
No I never checked the wiring to the motors.
Perhaps I'm wrong but the motors are working good, it is the direction of the axes that are not working and not the motors spin direction.
Nicolas
Nicolas
« Reply #45 on: August 15, 2009, 05:31:02 PM »
I meant YOUR wiring to the conections for the motors, not the motors themselves  ;)
What type of connectors are you using?
Offline kolias
  •  1,165 1,165
« Reply #46 on: August 15, 2009, 05:37:32 PM »
Still dont understand, you mean the wiring from the motors to the motor drives?
5 pin XLR connectors
Nicolas
Nicolas
« Reply #47 on: August 15, 2009, 05:41:52 PM »
If you unplugged the cables from a previously bad drive and plugged them into the good drive and that axis started behaving then it can only be a drive fault I would say.
Offline kolias
  •  1,165 1,165
« Reply #48 on: August 15, 2009, 06:29:14 PM »
I must agree with you Hood
Nicolas
Nicolas
vmax549
« Reply #49 on: August 15, 2009, 06:34:37 PM »
NOT being a stickler but
TO me this says you don't know if you did or not(;-)
But that is just MY opinion, but precise test proceedures are critical sometimes and assuming well you know the rest.
Just a thought, (;-) TP
