Hello Guest it is October 20, 2026, 09:57:57 PM
Author Topic: Wierd Start Stop Motion  (Read 28759 times)
Re: Wierd Start Stop Motion
« Reply #10 on: August 19, 2009, 11:43:08 AM »
I am not sure what you mean by 'attach your code'.  What code?
« Reply #11 on: August 19, 2009, 02:49:22 PM »
I mean this code
  However, the moment it tries to run g-code I get these predictable stops.
« Reply #12 on: August 19, 2009, 03:26:59 PM »
All code.  Any code.  From the Roadrunner to simple one line "g0 x0 y0" or "g1 x10 y10".  I am NOT having this problem just with one file.  I have this problem on all g-code files.
As I said in post 12, I can go to the MDI screen and enter "g0 x10 y10" and it stops at consistent intervals.  It doesn't matter what g-code I use.
It makes me suspect something about the difference between the way Mach3 generates pulses from g-code as opposed to generating pulses for a jog command or in the motor tuning mode.  Unfortunately, I don't know enough about how Mach3 does what it does to be able to speculate why it jogs smoothly but executes g-code with these stops.
Does that suggest anything to you?
« Reply #13 on: August 19, 2009, 03:30:57 PM »
Do the DROs show the stop start motion or do they count smoothly?
Run the driver test and see if that looks good.
« Reply #14 on: August 19, 2009, 03:39:28 PM »
The DRO's show the stops exactly.  The driver test shows very good results with very little latency.
« Reply #15 on: August 19, 2009, 03:48:49 PM »
That is weird, I have tried your xml here and it works well.  The only thing I see wrong in your xml is you have Output 1 enabled but you dont have a pin asigned to it but that shouldnt cause the problems you see.
As you dont have a great deal set up in ports and pins  it might be worth making a custom profile from scratch and trying that.
vmax549
« Reply #16 on: August 19, 2009, 09:14:46 PM »
THat sounds like the old quicktime syndrome. Something is interupting your driver in pulses.  While running a file, open the task manager and check for other programs running , also check the performance monitor for spikes in the cpu load that coinside with the stops.
« Reply #17 on: August 20, 2009, 01:52:05 PM »
HALELUJA!!!
I have a dedicated computer for this, and I thought I had stripped all non-Mach 3 software.  Somehow, I had forgotten to delete iTunes from the system.
No iTunes -- No wierd motion!  Thank you sooo much!
vmax549
« Reply #18 on: August 20, 2009, 09:54:34 PM »
GOOD JOB dude, (;-) TP
