Hello Guest it is November 10, 2026, 01:54:51 AM
Author Topic: Getting Started Creating Wizard for Mach2  (Read 15055 times)
« on: August 26, 2006, 10:09:56 AM »
I am new to Mach and am trying to figure out how to create/modify wizards. My machine uses Mach2 and the only screen designer I could find to download is the Screen4 program.  I downloaded the program, unzipped it into the Mach2 folder, and am able to open existing wizards from the Addons folders.  When I click any of the command buttons, I get an error saying "Text file for function calls missing...please reinstall".  I am a VB programmer so I am not worried about about being able to write the programs once I figure out how to get the programs working together.  Am I using the wrong screen edit/create program?
Thanks for your help.
Re: Getting Started Creating Wizard for Mach2
« Reply #1 on: August 27, 2006, 03:23:39 PM »
Look on the FTP server under Mach2.. I am going to upload Screen 3 for you.. that should work for you :)
www.newfangledsolutions.com
www.machsupport.com
