Hello Guest it is November 22, 2026, 07:03:51 AM
Author Topic: Anyone use "Import DFX's" before?  (Read 12712 times)
« on: August 05, 2009, 09:43:14 PM »
I used Mach3 R1.84.000 before, "Import DFX's" is a really good function to me.
Could I take out this function from older mach3 to new version mach3?
Thanks.
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Anyone use "Import DFX's" before?
« Reply #1 on: August 05, 2009, 10:38:10 PM »
Hi, Ymsio
I think it's built into mach3.184.000, I used ver 184 to generate pic below in ver MachR3.042.029 and it loaded.
Have you tried LazyCam, You should give it a try.
Chip
« Reply #2 on: August 07, 2009, 11:40:06 PM »
Hi, Ymsio
Chip
Hi, Chip.
I have tried LazyCam b4, but I prefer to use the "Import DFX's" function.
I will say that function is easier than lazycam. any idea to ectract this function for new version? :o
Thanks.
Offline Chip
  •  2,055 2,055
« Reply #3 on: August 08, 2009, 12:44:55 AM »
Hi, Ymsio
I think Art is the only one that could make it a standalone program.
You could install ver 184 without driver and rename the Mach3.exe to Mach3V184, Then reinstall the current ver your running, Then do your dxf's in 184 and run them in your current version.
Chip
« Last Edit: August 08, 2009, 01:01:05 AM by Chip »
