Hello Guest it is November 13, 2026, 03:17:15 PM
Author Topic: How to use the Run From Here option.  (Read 59523 times)
Re: How to use the Run From Here option.
« Reply #10 on: November 18, 2009, 02:48:18 PM »
Normally if you have a safe Z set it will move the Z to that first then X and Y then Z back down.
If however you had a safe Z set wrong it may go down in Z first.
« Reply #11 on: November 18, 2009, 03:26:38 PM »
I'll check it... However, It would be wise to program this into mach, that if current Z is higher than SAFE z, then do not go to that level...
(E.g. in my case "before" level was +3, target level was +2, and it went down to something lower than +2)
TOmorrow I do some air-tests...
« Reply #12 on: November 18, 2009, 03:28:43 PM »
If the safe Z is set to machine coords and it is there already or higher it will not move but I dont know about other options, would think however they to would do that.
« Reply #13 on: November 18, 2009, 03:39:55 PM »
For me it definetly went lower then target :(
« Reply #14 on: November 18, 2009, 03:42:23 PM »
Are there any tool length offsets in the code? maybe they are getting applied wrongly?
« Reply #15 on: November 18, 2009, 04:31:34 PM »
No tool length comp. at all, that is sure.
« Reply #16 on: November 18, 2009, 04:34:09 PM »
I seem to recall Art saying the difference between Run From Here and Set Next Line. I always use Run From Here but I think really you are only meant to use that if stopping in the middle of code and the Set Next Line is really meant for if you are starting fresh.
 Can't remember the difference but might be worth you trying it.
« Reply #17 on: November 18, 2009, 04:45:52 PM »
Ook, With fresh head tomorrow I`ll check it. I cannot recall any command button called set next line :)
Thanks anyways!
« Reply #18 on: November 18, 2009, 04:48:19 PM »
right above the Run From Here button on the standard screenset.
« Reply #19 on: November 18, 2009, 08:46:47 PM »
RC
