Hello Guest it is October 21, 2026, 04:32:50 PM
Author Topic: Macro, Thread milling NPT thread, Inside/outside  (Read 93899 times)
vmax549
« on: August 04, 2009, 08:44:38 PM »
Here is a macro that does thread milling of NPT tapered pipe threds.  IT is for a single point tool and does the threads as straight line segments NOT arcs. It will allow you to cut inside or outside threads . It does a standard thread taper angle
It has a programable front end that asks all the important questions to set up for each type thread. You set up major diam, tool diam , thread depth,etc
Please test before using to do something important. It works better on some computers better than others(;-) Different Ver of mach may react differently.
'Macro Thread Mill NPT taper pipe thread
Sub Main()
Setvar(21,Getdro(0))
Setvar(23,Getdro(1))
Setvar(30,Getdro(2))
Setvar(22,question("Threads per inch"))
Setvar(28,question("Tool Diameter"))
Setvar(27,question("Start Major Diameter"))
Setvar(9,question("Feed Rate"))
Setvar(18, question("Resolution of thread"))
Setvar(29,question("Thread Depth"))
Setvar(26,(getvar(30)-Getvar(29)))
N0:
Setvar(31,question("InsideThread(0)....OutsideThread(1)"))
If getvar(31)=0 Then GoTo N1
If Getvar(31)=1 Then GoTo N2
If Getvar(31)>1 Then MsgBox"Selection OUT OF RANGE"
GoTo N0
N1:
Code" #1=[[#27/2]-[#28/2]]"
COde" #8= [1+[-1*[FUP[#26/[1/#22]]]]]"
Code"#3=0.0"
Code"#10=[360 / #18]"
Code"#109=#10"
Code"#110=[1 / #22]"
Code"#111=[0.0625 / #22]"
Code"#3=#18"
Code"G00 X#21 Y#23"
Code"G01 Z[#30-#29] F#9"
Code"#19=[#1 + #21]"
Code"G01 X#19 Y#23 F#9"
GoTo N3
N2:
Code" #1=[[#27/2]+[#28/2]]"
Code"#3=0.0"
Code"#109=#10"
Code"#111=[-0.0625 / #22]"
Code"#3=#18"
Code"G00 X#21 Y#23"
GoTo N4
N3:
Do While Getvar(3) < 360.00000 * Getvar(8)
Code"#26=[#26 + [#110 / #109]]"
Code"#24=[COS[ #3 ] * #1]"
Code"#25=[SIN[ #3 ] * #1]"
Code"#24=[#24 + #21]"
Code"#25=[#25 + #23]"
Code"G01 X#24 Y#25 Z#26 F#9"
Code"#3=[#3 + #18]"
Code"#1=[#1 + [#111 / #109]]"
GoTo N3
Exit Do
loop
Code"G01 X#21 Y#23 F10"
Code"G00 Z1 M09"
Code"M30"
GoTo N5
N4:
Code"#3=[#3 + #18]"
GoTo N4
Exit Do
Loop
Code"G00 Z1 M09"
Code"M30"
GoTo N5
N5:
End Sub
End
Re: Macro, Thread milling NPT thread, Inside/outside
« Reply #1 on: November 17, 2011, 10:19:18 AM »
Can someone tell what FUP is in the macro?
Jeff E.
« Reply #2 on: November 17, 2011, 04:38:50 PM »
Jeff, not sure what you mean by FUP.
« Reply #3 on: November 18, 2011, 03:51:06 AM »
Hi Rich,
When looking through the code, there are instances where it says:
« Reply #4 on: November 18, 2011, 05:22:45 AM »
Thanks Bud...time for a new pair of glasses and don't what it means  Jeff.
« Reply #5 on: November 18, 2011, 09:37:02 PM »
Mach3 manual section 10.5.3.4
FUP(round up)
« Reply #6 on: May 29, 2017, 06:49:23 PM »
Hi vmax549,
I am trying to run your code under VBS, and return 'COMPILE ERROR: SYNTAX ERROR' at :
Do While Getvar(3) < 360.00000 * Getvar?
why?
  •  9,374 9,374
« Reply #7 on: May 30, 2017, 03:14:55 AM »
Hi Shanren,
I think that line of code should read :-
Code: [Select]
Do While Getvar(3) < 360.000 * Getvar(8)
« Reply #8 on: June 05, 2017, 07:04:21 PM »
Hi Tweakie.
you are right, thanks.
another question, what's the 'resolution of thread' means? what should fill in for 1/4 NPT?
Best
Shanren
  •  9,374 9,374
« Reply #9 on: June 06, 2017, 01:32:32 AM »
I have absolutely no idea - I am sure Rich will be able to answer that question.
