Hello Guest it is October 20, 2026, 03:57:13 PM
Author Topic: Tooltable unkown values  (Read 16858 times)
« on: August 04, 2009, 05:57:22 AM »
my CNC for my mill still isn't finished yet, in the meantime I'm playing with Mach3. When I open the tooltable I get funny numbers in the 2.line of the list ( see attachmet)on 2 of my computers. I tried different versions of Mach, no change. In a German forum a read, that some users have also odd numbers, others don't. This is not a really problem for me, but since some people don't have those numbers, perhaps I did something wrong.
regards
Klaus
The brain isn't a soap, it doesn't shrink when used.
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Tooltable unkown values
« Reply #1 on: August 04, 2009, 02:32:10 PM »
Hi, Klaus
In Mach3\macros\"the porfile your using"\Tool3.dat, Delete it or re-name it and restart Mach3 then recheck it, Apply OK, Check in again after another restart of Mach3.
Chip
« Reply #2 on: August 05, 2009, 02:17:17 AM »
Hi Chip,
is still the same. The tools3.dat contains
255 entries with [length of string] folowed by "Empty" and 63 times NIL
followed by 255 times 01
I don't think those odd numbers come from the tools3.dat. Some other user have different numbers. For me it looks more like an uninitialized variable / pointer.
Klaus
Offline Chip
  •  2,055 2,055
« Reply #3 on: August 05, 2009, 10:26:51 AM »
Hi, Klaus
What version of Mach3 are you using, It may be in the "profile"  Mach3Mill.xml your using, Rename and post it hear, I'll look at it.
Chip
« Reply #4 on: August 05, 2009, 04:16:26 PM »
Hi Chip,
I tried version 2.61 and 3.043 and always used the Mach3Mill.xml profil. Before installation I deleted the complete Mach3 directory. I'm supprised no one else in this forum has the same phenomenon.
Klaus
« Reply #5 on: August 05, 2009, 04:58:58 PM »
Is it perhaps due to being in demo mode? Mine looks like Klaus's, but with different numbers. I don't have a license, could that be why? (I don't have a machine, either - at least not quite yet. :) )
« Reply #6 on: August 06, 2009, 02:07:17 AM »
Hi Gerry,
I don't think so, it looks the same with or without the license file copied to the Mach3 dir.
Klaus
Offline Bengt
  •  54 54
    • Private CNC site
« Reply #7 on: August 17, 2009, 01:56:29 AM »
Klaus,
You are not alone as I am having the same kind of problem with other set of figures.
http://www.machsupport.com/forum/index.php/topic,12342.0.html
ger21
I am also thinking in these terms but my NFS wizards are working OK so my license appears to be OK
If it is a licensing issue then I am not happy as I have several days of crashed material with funny tool movements
Bengt
