Hello Guest it is October 20, 2026, 03:09:55 PM
Author Topic: mach3 motor configuration  (Read 25443 times)
Re: mach3 motor configuration
« Reply #10 on: July 30, 2009, 07:01:58 AM »
Please attach your xml.
I reinstal the sistem now and choose the Standard PC - I dont have any file left on it !
But What xml do you need ?
« Reply #11 on: July 30, 2009, 07:17:32 AM »
If you still have the problem then I need the xml for the profile you are using. Example if you use Mach3Mill then look in C:\Mach3 and find Mach3Mill.xml, copy it to your desktop and rename to birlan.xml then attach it to your post by using the additional options button.
« Reply #12 on: July 30, 2009, 02:04:36 PM »
After fresh reinstall with (Standard PC) option  - everithing is working now !
Thank you all !
