Hello
Guest
it is
September 29, 2026, 07:01:27 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
pocket macro in g-code form
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: pocket macro in g-code form (Read 17553 times)
enytned1
51
on:
July 20, 2009, 08:30:58 AM »
Does anyone have a pocket macro in g-code (fanuc or mach) style? Looking for something that will have a length, width, depth x,y position. Any and all help would be much appreciated.
Logged
Re: pocket macro in g-code form
Reply #1 on:
July 20, 2009, 08:42:15 AM »
have you looked at the Wizards?
Logged
enytned1
51
Reply #2 on:
July 20, 2009, 08:49:27 AM »
I know there are wizards, i need the actual macro written in g-code with if or while commands. Is there a way to see the source code for the wizards?
Logged
vmax549
Reply #3 on:
July 20, 2009, 09:00:45 AM »
MACH cannot do direct conditional gcode programing, (;-(. BUT I may have something you can use to cut squareish pockets.
Last Edit: July 20, 2009, 09:03:13 AM by vmax549
Logged
enytned1
51
Reply #4 on:
July 20, 2009, 09:11:20 AM »
This is not for a Mach control. I will use this on a Fanuc router.
Logged
Carnoustie, Scotland
Reply #5 on:
July 20, 2009, 10:40:04 AM »
You can look at the VB in the wizards by going into the wizard you wish and then Operator menu the Edit Button script. The Post code button should flash and when you look it should open the editor with the VB in it.
Whether that will be any use for your Fanuc I dont know.
Logged
vmax549
Reply #6 on:
July 20, 2009, 07:23:36 PM »
Try THis
#1=100(LENGTH)(A)
#2=200(WIDTH)(B)
#3=6.5(DEPTH)(C)
#17=20.6(TOOL DIA.)(Q)
#8=.7(TO CUT LESS THEN 1/2 CUTTER FOR OVERLAP)(E)
#21=2(Z PICK)(U)
#9=200(FEED)(F)
#23=.5(FINISH STOCK ON WALLS)(W)
#20=10(TOOL NUMBER)(T)
O0001(MAIN PROGRAM)
G65P9000A100B200C6.5Q20.6E.7U2F200W.5T10
M30
O9000(RECT. POCKET MACRO)
M6T#20
#10=[#17/2]-#8
#1=#1/2
#2=#2/2
#17=#17/2
#11=0(Y COUNTER)
#12=#21(Z COUNTER)
N100G0G90X0Y0Z1.
Z.1
G1Z-#12F#9
N200
WHILE[#11LT[#1-#17-#23]]DO1
#11=#11+#10
IF[#11GE[#1-#17/2-#23]]TH#11=[#1-#17-#23]
X-[#2-#17-#23]
Y-[#11-#23]
X[#2-#17-#23]
Y[#11-#23]
X-[#2-#17-#23]
Y0
END1
IF[#12EQ#3]GOTO300
#12=#12+#21
IF[#12GE#3]TH#12=#3
#11=0
GOTO100
N300
IF[#23EQ0]GOTO400
#23=0
GOTO200
N400G0Z1.
M99
(;-0 TP
Logged
Print
Pages:
1
Go Up
« previous
next »
