Hello Guest it is November 11, 2026, 11:13:44 PM
Author Topic: need help with Mach set-up for Xylotex and c6 spindle speed control  (Read 7687 times)
Hi
Can anyone help?
I have the Xylotex 4 axis running X,Y,Z and A on my X2 mini mill....  no problems at all.
I would like to control the spindle with Mach and have purchased the CNC4PC C6 board.
Stand alone 12vdc power to the C6 no problem, connecting the Xylotex pin 14 (step) and pin 1 (dir) and Pin 18(gnd) to the C6 not sure.
Measure 0 - 10vdc at analogue output terminals on the C6 ....  nothing?
Mach setup is as per the CNC4pc C6 instructions, however I've assigned the (step) to pin 14 and the (dir) to pin 1.
I'm not sure what I'm missing but I can't get the (step and dir) to the C6 nor any analogue out.
If someone could walk me through this, that would be great.
Thanks Tim
