Hello Guest it is November 13, 2026, 03:01:59 PM
Author Topic: step rate  (Read 17795 times)
step rate
« on: July 18, 2009, 12:12:37 PM »
How do you change the tep rate in Mach3?
Re: step rate
« Reply #1 on: July 18, 2009, 01:41:06 PM »
What are you meaning by the step rate?
Re: step rate
« Reply #2 on: July 18, 2009, 02:53:23 PM »
The X-axis stepper is stalling, another forum told me to reduce the step rate and I'm not sure how to do it.
Re: step rate
« Reply #3 on: July 18, 2009, 02:55:04 PM »
If a motor is stalling then you want to reduce the Velocity or Accelleration, you will find them on the motor tuning page from Config menu. Remember to save axis settings after you have changed them.
Re: step rate
« Reply #4 on: July 18, 2009, 03:03:06 PM »
I have tried many different combinations and still have a stalling issue. There is no mechanical prolems, and the stalling happens a random times during a run. Sometimes as long as thirty minues in.
Re: step rate
« Reply #5 on: July 18, 2009, 03:17:23 PM »
what pulse width do you have set? What make of drives do you have? What breakout board do you have? What kernel speed are you using?
Re: step rate
« Reply #6 on: July 18, 2009, 03:24:21 PM »
Pulse with 3, kernal speed 25000, HbbyCN boad with nema23 305oz motors. Thanks for taking the time to help.
cb
Re: step rate
« Reply #7 on: July 18, 2009, 03:27:15 PM »
not familiar with the HobbyCNC stuff but try swapping drive between X and Y if it is possible, also make sure enhanced pulsing is enabled on General config page.
Re: step rate
« Reply #8 on: July 21, 2009, 06:05:26 AM »
What kind of computer and OS are you using?
You might try opening the task manager and clicking the performance tab to see how much CPU you are using. If it pegs, the motors will stall. Even reasonably powerful computers can have so many background tasks running that Machruns on leftovers.
Stop any antivirus/antispyware software while running Mach.
Make sure you do not have any printer drivers installed in the computer. That can also stall the motors when the driver polls the port.
Re: step rate
« Reply #9 on: July 21, 2009, 08:05:17 AM »
It may just be resonance. You might try making a damper if yo have dual shaft motors. There's a long thread at CNC Zone on it.
