Hello Guest it is November 13, 2026, 12:48:34 PM
Author Topic: db25 parallel v. serial pinout voltage  (Read 19722 times)
« on: July 17, 2009, 10:55:22 PM »
Hi. I've got a cnc laser from the late 80's and I'm trying to retrofit it to use mach3. What concerns me is the 12 volt pin. If I plug this into my parallel port will this voltage fry my mother board? The pinout is as follows:
MOVER-MPG Reference (1987-1990)
Signal H4 DB25F Pin
Step1-5
Step2-6
Step3-7
Step4-8
Dir1-18
Dir2-19
Dir3-20
Dir4-21
Device0-Enable 9
Device1-Enable 22
+12V-11
+5V-24
Ground, Logic Common-13,25
Signal H5 DB25M Pin
Limit1-19
Limit2-6
Limit3-18
Limit4-5
Limit5-17
Limit6-4
Limit7-16
Limit8-3
+12V-14
+5V-13
Ground, Logic Common-1,12
Re: db25 parallel v. serial pinout voltage
« Reply #1 on: July 18, 2009, 02:05:10 PM »
Yes, if the wire has 12v on it you will kill the port.
« Reply #2 on: July 18, 2009, 05:28:21 PM »
Would a serial port take the voltage?
« Reply #3 on: July 18, 2009, 05:45:58 PM »
I think RS232 is 12v but  I am far from an expert so take that with a huge pinch of salt.
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #4 on: July 18, 2009, 06:24:12 PM »
Hi, Ohpakron
You need to post moer info on your laser setup, Maybe some pic's, how many stepper's, control board's....
Chip
« Reply #5 on: July 19, 2009, 05:52:50 AM »
I *think* you can use a 1k resistor in the 12V to knock it down to 5V
BUT, please confirm that with the electron guys before you act on it. I am unqualified in the area of electronics.
« Reply #6 on: July 19, 2009, 09:57:02 AM »
Not sure what you are trying to do? if any signal or output pins on the machine end Source 12v then you are going to need an interface of some kind, If it is just the 12v pin you are worried about, why not just leave it open?
This is if the signals can be operated by 5v TTL.
(RS232 serial is + and - 9v minimum.)
If you do not have a diagram that outlines the nature of the I/O, then you could do a bit of reverse engineering to see what kind of components and signal levels are used to feed the ports.
Nosmo
