Hello Guest it is November 13, 2026, 09:44:17 AM
Author Topic: motor does not run  (Read 52637 times)
Re: motor does not run
« Reply #30 on: July 25, 2009, 06:47:12 AM »
Debounce only masks the problem it does not cure it as such, you will still have the noise or bouncing switch issue underneath. Personally I always say to people to set the debounce to 2000 and if it helps then the problem has been found and really it should be cured by properly shielding and grounding or getting switches that dont bounce.
