Hello Guest it is November 13, 2026, 01:54:24 PM
Author Topic: motor does not run  (Read 52667 times)
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: motor does not run
« Reply #10 on: July 21, 2009, 08:53:38 PM »
Hi, Rich
Not sure how you have your limits wired, Change the Active Low for all of the Home & Limit's should allow you to Reset. Just 1 Input Pin can do it if all SW's are wired NC and then in series to  each other. One end to Gnd. the other end to an Input Pin.
Chip
« Reply #11 on: July 22, 2009, 04:54:36 PM »
Chip,
This is exactly how I have the limits set (plus the estop).  All are wired in series.  All NC.  If I hit one of the limit switches (with my finger), all the LEDs light in the configuration window.  If I let go, they go out.  But it won't reset.  It says "external estop requested" and scrolls "press reset...emergency mode active".
Here is the port 1 pin state in the configuration window (x=on, o=off):
ooo*********oxoooo
oooooooooooo
If I hit the limit switch (capital X comes on):
ooo*********Xxoooo
oooooooooooo
« Reply #12 on: July 22, 2009, 05:00:41 PM »
Settings page and Enable Auto Limits Override.
« Reply #13 on: July 22, 2009, 05:08:15 PM »
Chip,
That didn't show well.
Try these screan shots:
« Reply #14 on: July 22, 2009, 05:10:32 PM »
Auto limit override is enabled.
The before shot"
« Reply #15 on: July 22, 2009, 05:11:05 PM »
Just reading again, how do you have the E-Stop wired?
« Reply #16 on: July 22, 2009, 05:13:35 PM »
Can you attach your xml please and I will see what happens here with it, often easier to catch something that way.
« Reply #17 on: July 22, 2009, 05:31:17 PM »
« Reply #18 on: July 22, 2009, 05:32:51 PM »
Using limit switches as estop.
« Reply #19 on: July 22, 2009, 06:15:47 PM »
All seems to be working fine here but I am just simulating the switches. Is there a chance that you have noise or a switch thats not closing correctly?
