Hello Guest it is November 22, 2026, 08:45:34 AM
Author Topic: Servo motor configuration  (Read 13678 times)
ericma
« on: August 23, 2006, 06:32:09 PM »
Is anybody knows how to hookup the servo motors with Mach3? How many pins are needed to control one amplifier of the servo motor?
I have five servo motors and two parallel ports in my computer. Is the Mach3 is powerful enough to handle all the five servo motors?
Thanks a lot!
Eric Ma
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Servo motor configuration
« Reply #1 on: August 24, 2006, 06:04:21 AM »
Hi, Eric Ma
Your servo controls need to be step and direction, 10 pins for this,Mach3 would work fine.
Hope this Helps, Chip
ericma
« Reply #2 on: August 24, 2006, 11:04:07 AM »
Hi Chip:
The wiring of the amplify for a servo motor is pretty complicated
I am working on the Yaskawa servo motors. There are 50 connectors in amplifies terminal.
Could you please direct me that which two connectors should be wired to the two parallel pins?
I am very appreciated your help!
Eric
« Reply #3 on: August 24, 2006, 03:55:56 PM »
Eric,
This is the example given for the Sigma Series Yaskawa.
You have to set these drives up for this operation with the drive software also.
Darek
