Hello Guest it is November 13, 2026, 09:42:10 AM
Author Topic: Smoother Radi's  (Read 24930 times)
Offline SScnc
  •  77 77
Smoother Radi's
« on: July 09, 2009, 08:25:12 AM »
I built my own CNC mill which works great. My only concern is that when i cut a radius, it leaves a "choppy" finish on the material. Is there any way i can smooth this out? Possibly something i can set with Mach3. Thanks
My setup is Gecko G540, Keling 48v PS, Keling 270oz motors, etc..
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
Re: Smoother Radi's
« Reply #1 on: July 09, 2009, 08:37:52 AM »
Sounds like you have a lot of backlash/slop in your drive system. Have you measured your backlash.
Happy machining , Jeff Birt
Re: Smoother Radi's
« Reply #2 on: July 09, 2009, 09:46:19 AM »
You could make a rough and then do a finish cut. Experiment with your particular machine a little to see what works best.
Re: Smoother Radi's
« Reply #3 on: July 09, 2009, 09:57:21 AM »
Is the code an arc or many short lines?
Re: Smoother Radi's
« Reply #4 on: July 09, 2009, 10:03:28 AM »
What program are you using to generate the code?
Offline SScnc
  •  77 77
Re: Smoother Radi's
« Reply #5 on: July 09, 2009, 11:55:17 AM »
-No Backlash
- I do rough then finish
-Code is an Arc
-I use CamBam Plus
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
Re: Smoother Radi's
« Reply #6 on: July 09, 2009, 01:55:51 PM »
-No Backlash
Impossible, every thing has some amount of backlash! Have you actually measured it with a good dial indicator??
CamBam produces good Gcode. Your fixture/part/machine has to have some excessive sort of slop or backlash OR you are taking way to aggressive a cut.
Offline SScnc
  •  77 77
Re: Smoother Radi's
« Reply #7 on: July 09, 2009, 02:34:44 PM »
well obviously it has backlash but i have backlash comp on. Its less then .0002 on each axis.
.010 finish cut, climb milling.
Re: Smoother Radi's
« Reply #8 on: July 09, 2009, 04:14:56 PM »
What is your step per unit?
Offline SScnc
  •  77 77
Re: Smoother Radi's
« Reply #9 on: July 09, 2009, 07:13:38 PM »
not sure of exact numbers but it is around 10k
