Hello Guest it is November 13, 2026, 12:45:29 PM
Author Topic: Sequence to zero XYA--Z  (Read 12827 times)
« on: July 07, 2009, 08:03:39 PM »
I am using 4 axis and I need when move all axis to zero first X and Y after this Z and A. Today happens this way:
when I click GotoZ, X Y and A go to zero and after this z go to Zero.
What I need to mach3 do this sequence?
Thanks ???
Re: Sequence to zero XYA--Z
« Reply #1 on: July 09, 2009, 01:02:48 AM »
You would need to make up a VB button if you wis to do the sequence differently as the GoToZ is coded into Mach.
 Having said that maybe all you are needing to do is set a safe Z, if you do that setting the safe Z as machine coords 0 then what will happen when you GoToZ is the Z axis will rise fully up the X, Yand A will go to your offset  zero then finally the Z will move down to your offset zero.
« Reply #2 on: July 09, 2009, 05:19:58 AM »
Thanks Hood,you Know if somebody have the same question about this ?
« Reply #3 on: July 09, 2009, 07:38:09 AM »
Sorry dont really know what you are asking :(
